Ducati Diavel Dark Stealth
Geplaatst: di 06 okt 2015, 08:12
Hoi!
Graag wil ik jullie voorstellen aan mijn andere liefde, de Ducati Diavel Dark Stealth! Deze motor voldoet wat mij betreft aan alle definities van dik!
TypeTestastretta 11° L-Twin, 4 Desmodromically actuated valves per cylinder, liquid cooled
Displacement1198.4cc
Bore x Stroke106 x 67.9mm
Compression ratio12.5:1
▂Power119 kW (162 hp) @ 9,250 rpm
▂Torque130.5 Nm (96.3 lb-ft) @ 8,000 rpm
Technical data referring to power and torque was measured on an engine test stand at Ducati.
Fuel injection Electronic fuel injection, elliptical throttle bodies, fully ride-by-wire controlled
ExhaustStainless steel muffler with aluminium tips; catalyzer and 2 lambda probes
Transmission
Gearbox6 speed
Primary driveStraight cut gears, ratio 1.84:1
Ratio1=37/15 2=30/17 3=27/20 4=24/22 5=23/24 6=22/25
Final driveChain drive; 15 tooth front sprocket, 43 tooth rear sprocket
ClutchSlipper and self-servo wet multiplate clutch with hydraulic control
Chassis
FrameTubular steel Trellis frame
Front suspensionMarzocchi fully adjustable 50 mm usd fork with DLC-treatment
Front wheelLightweight alloy, 14-spoke with machined finish 3.50" x 17"
Front Tyre120/70 ZR 17 Pirelli Diablo Rosso II
Rear suspensionFully adjustable rear shock with progressive linkage. Remote spring preload adjustment. Single-sided aluminium swingarm
Rear wheelLightweight alloy, 14-spoke with machined finish, 8.00" x 17"
Rear tyre240/45 ZR17 Pirelli Diablo Rosso II
Front wheel travel120mm (4.7in)
Rear wheel travel120mm (4.7in)
Front brake2 x 320 mm semi-floating discs, radially attached Brembo Monobloc 4-piston callipers with ABS as standard equipment
Rear brake265mm disc, 2-piston floating calliper ABS as standard equipment
InstrumentationHandlebar mounted instrumentation with LCD display: speed, rpm, time, coolant temp. Warning lights for: Neutral, turn signals, high-beam, rev-limit, DTC intervention, ABS status, oil pressure, fuel reserve. Tank mounted instrumentation with TFT colour display: gear selected, air temp, battery voltage, trips 1 & 2, fuel reserve trip, average and actual fuel consumption and speed, trip time, scheduled maintenance. Full status and/or management of Riding Modes, DTC, RbW and ABS.
Dimensions and weight
Dry weight210kg (463lb)
Weight data refers to the dry weight of the motorcycle without battery, lubricants and coolants for liquid-cooled models.
Wet weight (KERB)239kg (527lb)
Kerb weights indicate total bike weight with all operating consumable liquids and a fuel tank filled to 90% of capacity (as per EC standard 93/93).
Seat height770mm (30.3in)
Wheelbase1580mm (62.2in)
Rake28°
Trail130mm (5.1in)
Fuel tank capacity17l - (4.5 US gal)
Transmission
Gearbox6 speed
Chassis
Rake28°
Trail130mm (5.1in)
