U4GM How to unlock the Deadeye Drone streak in Black Ops 7
Geplaatst: di 16 dec 2025, 04:46
If you’ve been living in Black Ops 7 since Season 1 kicked off, you’ve probably clocked the weird gap where the Deadeye Drone should be. The trailer made it look nasty, then launch day came and… nothing. People kept asking if it was cut, delayed, or tucked behind some secret menu. Nope. It’s just tied to the Weekly Challenge track, and once you spot that, it makes sense—especially if you’ve ever messed around with a CoD BO7 Bot Lobby to warm up and bang out objectives without the usual chaos.
Why it didn’t show up at launch
Week 1 and Week 2 came and went with no sign of it, which is why the community started spiralling. BO7’s been doing this drip-feed thing where a flashy item appears in promos, then arrives later as a challenge reward. It’s not new, but it does catch you off guard when you’re expecting to equip it straight away. The upside is it’s not locked behind a bundle, so at least everyone’s got a fair shot.
The actual unlock requirement
Here’s the part you’ll care about: the Deadeye Drone unlocks in Week 3, and you need to complete six Week 3 challenges to claim it. Not five. Six. That little detail matters, because a lot of players will finish a handful, back out, and wonder why nothing popped. Once the sixth one ticks over, the reward unlocks immediately.
You’re not stuck in one mode
Week 3 gives you a big list—24 challenges total—spread across Multiplayer, Zombies, Endgame, and Warzone. The game doesn’t force you to be a hero in every playlist either. You can mix them up, like four in Zombies and two in Multiplayer, or just stay in your comfort zone and grind all six in one place. It’s nice, honestly, because some weeks MP feels like a full-time job.
No need to speedrun it
A lot of folks panic the moment Week 3 hits, like it’s a 48-hour window. It isn’t. The challenge stays active through Season 1, so if you miss a few days, you’re fine. You can knock it out later when the lobbies calm down, when your friends are on, or when you’re just in the mood to chase checkmarks instead of wins.
What you’re getting once it’s unlocked
In match terms, the Drone costs 575 score, which is doable even if you’re not dropping highlight reels. When you finally call it in, it’s a remote-controlled threat with enough bite to change how people hold lanes and rooftops. There are also two Overclocks to grind afterward: one that boosts the sniper rifle component with an Extended Mag, and another Grenadier upgrade that lets you drop aerial bombs.
How players are likely to use it
You’ll see it used for cheap intel and nasty picks—send it down a hallway, clear a headglitch, force someone off a power spot. And because it’s not insanely priced, people will chain it into mid-tier streak setups and snowball momentum. If you want it fast without turning every match into a sweat-fest, lining up challenge progress with your normal play is the move, and some players even keep things low-stress with u4gm CoD BO7 Bot Lobby while they focus on ticking off the last few requirements.
