Hi, I'm sorry I'm not really introducing myself, I have a quick question.
I already posted it on another forum, but it seems to be pretty dead (and it's kind of urgent).
I'm looking for the fuel pump relay fuse.
I found a diagram on another forum, but it doesn't seem to correspond with my fuse box.
I have a 2017 Move up! with a 1.0 liter 3 cylinder (60HP) engine and automatic transmission.
This is the diagram:
http://knigaproavto.ru/shemy/en/volkswa ... agram.html
This is my fuse box:
https://i.imgur.com/qrBcT2D.jpg
Thank you guys in advance!
Fuel Pump Relay Fuse
- Bertjuh
Re: Fuel Pump Relay Fuse
It should be the bigger 15A fuse in the lower row..
The bright blue one..
Thank you so much Bertjuh for your quick reply!Bertjuh schreef:It should be the bigger 15A fuse in the lower row..
I should've mentioned that I already tried this one (as it matches with the diagram) but I tried removing it, and when I turn the key, right before starting the engine, I can hear the fuel pump buzzing, so I assume this wasn't really the fuse we were looking for?
I'm not very tech savvy but I assume the pump shouldn't buzz anymore when I turn the key if the fuse is disconnected, right? Or am I missing something?
Thanks!
